synchronize View
synchronize View
Hello Autodesk Revit Team
Please Add a Tool for synchronizing Duplicate view for better control of the views.
that's like  BlueBeam
4 Comments
amyyishanding
Observer
Please add capability/toggle option for the pan and zoom of open plans and 3D views to be synched with each other.
Tags (4)
A lot of times I switch between floors to compare shafts. But when I switch views I'll have to find the exact shaft that i was looking for which can become time consuming, especially when lagging. Also i need to be able to switch back and forth to become aware of minor differences, which can only be detected, if both views are showing the exact same spot. It would be really useful to be able to link multiple views, so that when I switch to another view, I'll in the exact same spot as I was before, based on the coordinates.
TimHevel
use pyRevit's "sync views" in the meantime
Hi, @Anonymous
Here are two similar Ideas. If you like, I can combine them with yours.
Synchronize Open Plan and 3D Views - Autodesk Community
synchronize View - Autodesk Community
Thank you for your contribution!
Kimberly
