cancelar
Mostrando los resultados de
Quiere decir:
Symbolic vs Boundary lines in Filled & Masking Regions
Currently filled and masking regions only allow for boundary lines, although they typically aren't referred to that way. Regions only permit a single closed loop of lines to create the boundary. Compare to the way linework functions in shafts, where you can create the boundary but also create symbolic lines that are not part of the closed loop condition. Could be very useful in specific cases to avoid making superfluous groups, when it doesn't make sense to go to the effort of making a family. Since this functionality already exists for shafts, it seems like it should be easy to implement in filled and masking regions.
4 Comentarios
No aplicable
Sounds like you could just create Detail Component families?
No aplicable
And I would be the first to do so, if the situation warranted it. Not every case warrants a new family, though.
No aplicable
Do you have a god graphic example?
No aplicable
I agree! It would be nice to have the "Symbolic Line" in the filled and masked regions.
Enviar idea
