Superscript and Subscript Text in Revit
The text editor is plagued with a lot of issues and I know a more advanced Revit text editor has been requested repeatedly over the years. To add to this, I'd like to see superscript and subscript options in Revit text as well.
7 Comments
SeanSpence
Here. Here!!
I just added a similar suggestion before seeing yours.
Thank you for implementing this in 2017
sasha.crotty
Thanks for submitting your idea. As this capability is available for Text Notes in Revit 2017, I'm marking this idea as Implemented.
Tarek_K
Status changed to: Gathering Support
Tarek_K
kacyevs56
If it was implemented, could someone please explain how to do it.?
lionel.kai
@kacyevs56 while editing text, look in the Ribbon:R2023 - Modify - Text Notes (Subscript & Superscript highlighted).png
For all: I created an idea to implement Subscript & Superscript for Dimensions so that they would match the Text without needing to use separate floating elements.
I also re-posted Subscript & Superscript for Labels (Tags) and Properties for completeness.
