When you add a tie column into a wall it should cut the wall. Right now we have to split the wall where the column has been added and drag the wall footing under the tie column if it doesn't have an isolated footing of it's own. As we work the model we have to continually check to make sure the column hasn't joined the wall because, if it does, the column then disappears and looks like the wall hatch instead of standing out like it should. There should be a setting to keep the columns from joining with a wall.
