Steel connection - bolt tag - I wish to remove the unit (mm)
I wish the option to remove the unit when using the "diameter" label in a steel connection bolt tag.
I tried to do a work around and create my own label with "diameter" included but it is not possible to use the diameter parameter.
I work in R2021.
4 Comments
robert.jungergard
Hi ToanDN,
When I select the diameterlabel the button is greyed out.
I see you are correct.  Diameter come from the bolt database and is not accessible.
robert.jungergard
I have installed Advance Steel and from there on you can modify and the bolt list.
I chose Advance Steel since it's in our license packaging, but I think you can modify it with a program that can access .mdf files, perhaps Microsoft Access or some SQL program.
In the database you can "clean up" and delete what you don't wish to use.
