cancelar
Mostrando los resultados de
Quiere decir:
Stairs should have plan region built in
When creating a stair, there should be a plan region option automatically built in so you can adjust the height of the cut without having to add a plan region manually every time.
Or call it "Cut Height" and have an Instance setting that allows you to adjust that way....
2 Comentarios
YarUnderoaker
"Cut Height" must be per view parameter, but Revit does not have per view parameter for model element except rebar.
So developer must do a new entity - view modifier for applying it on stair. This is almost the same as plan regions, but it is applied strictly with stairs without affecting neighboring objects.
lionel.kai
Maybe just a context option to create a Plan Region for the selected Stair (that encloses the extents). That said, it would be helpful to make it a property so you don't have to deal with the unexpectedly large Plan Regions for diagonal stairs (see Stairs' cut symbol in wrong position within plan regions, etc.)
related idea: Cutmark for Stairs going down (&/or obey view range for treads below)
Enviar idea
