I have been using Revit MEP since the 2011 release. I noticed that the stainless steel press fit families are no longer available in the library since the 2013 release. I have the fittings that I used in my template file, which I upgraded, but the 2016 version does not provide the look up table. Therefore the result I was getting is a fitting that states it is the correct size, but in fact it is not.
I have imported the look up table for the copper fittings into the stainless steel family, as they look exactly the same and this works. However, I think it would be sensible to provide the stainless steel press fit families with look up tables in the new releases, as they are used frequently and will cause issues for other users.
Thank you
Jillian
