Stacked wall clean ups
This has always been an issue since I started using Revit back in 2009.  Stacked walls only seem to clean up correctly if they are intersecting another stacked wall of the same type.  If there is any variation in material elevation with the stacked wall it is joining, the stacked walls are almost impossible to have clean up and look correct in plan.  This needs to be rectified as it has been happening for way to long.
1 Comment
Ric_Weber
I've had issues with them cleaning up correctly even if they are two of the same type of stacked wall!!  My work around has been to stop using stacked walls.  Which I wish I wouldn't have to do, because I love the concept of how they work.  They just don't work great in reality!  Autodesk, please fix.
Autodesk Customer Advisory Groups
