Spot Elevation Rotation
I have a project where one of the blocks is not oriented to Project North or True North.  So I have a skewed scope box which allows the views to be placed square on a sheet.
All is good, except the spot elevations labels are aligned to the Project North whereas all the other annotation is  oriented to the view or the component they're attached to.
There should be an instance or type option to choose the rotation of the Spot elevations - Project or View.
There is a "Rotate with Component" type property, but that only changes the rotation of the symbol, not the text.  This aligns the symbol with either Project North i.e. the label or the view.
1 Comment
ecentenera
you can only tweak the spot elev by enabling the shoulder and disabling it leaving the leader alone to rotate the spot elevation.  wish that it can be rotated though... rotate with component doesn't solve it either.
