I would like to be able to split walls horizontally in elevation or section view. Currently, when we receive models from the Eng or Architect they will draw the walls full height of the structure. However, in construction, we typically split the walls at each level unless it is a tilt panel. We can copy monitor most of the walls in the model and split at each level and then stop monitoring the walls. Sometimes walls are missed and we will need to split them and the only way to do this now is to copy and paste in place then change the base/top offset. It would be a big time saver if we could split the wall horizontally.
