Spiral pile rebar with variable step increase
On behalf of the customer.
There is a need for the possibility to create a spiral pile rebar with variable number of turns per unit height. That means that there should be a possibility to create a rebar which has e.g. 20 turns per 1m on the firs 2 m of length and further 10 turns per meter. It should be similar to the variable rebar distribution.
The aim is to tag it as a on rebar position.
