Slope Arrow should be defined by actual slope, not only by heights
Slope Arrow, in roof and floor sketch, should let you define it by degrees, ratio, rise or slope percentage (whatever you chose in project units) not only by diferrence in heights of the arrow head... that would by a very time saving option.
This parameter it's shown on the properties panel of slope arrows, but you can edit it. It makes no sense for me.
4 Comments
samuelsanf
Here an example of a situations when you need to use not so practical workarounds to get the precise slope you need on roofs... the same would happens for parking drainage.
https://forums.autodesk.com/t5/revit-architecture-forum/roof-that-slopes-in-2-directions/td-p/678982...
Another workarround is to define the height of subelements on floors, but you have to edit the height of multiple points and do it manually on sections with a line as a reference to get a perfect slope (if not you will obtain a floor with interior edges for me the slightest change of slope).
Of course another option it creating in-place components and change their category... but it is a less desired way, and I think with Revit LT you can't do it.
samuelsanf
My bad, it's actually possible.
Revit have a plenty of things, and you can always learn some new.
sasha.crotty
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
sasha.crotty
Status changed to: Archived
