cancelar
Mostrando los resultados de
Quiere decir:
Slanted walls
Slanted walls
Revit 2019 does not accommodate for slanted walls. The only  way around this problem is to create a mass  or create a generic component. It would be beneficial if the angle of a standard wall could be defined at different points.  similar to a floor.
 Thank you
2 Comentarios
dplumb_BWBR
That idea has been marked as an "Accepted Revit Idea" on the Revit Road Map
https://blogs.autodesk.com/revit/2019/08/23/revit-public-roadmap-august-2019/
El estado se ha cambiado a: Implemented
Thank you for your Idea submission. This feature was Implemented in Revit 2021.
Enviar idea
