Show levels in 3D views - even if camera is parallel to it
When working in 3d views you get to see the project's levels in some sort of out of the way head-up-display way. That is most of the time. These levels disappear when you view cube to either top or bottom direction. While this maybe a wanted feature it should only be an option. Especially in perspective views from above showing the levels would be really helpful and relevant.
