cancelar
Mostrando los resultados de
Quiere decir:
Sheet Layout Templates
Would like to see Sheet Layout Templates.
Template sheets with view placeholders and other default settings (e.g. text , lines) might help to speed the process of creating sheets
Quite often we have to create many sheets with the same layout. For example we add a 3D, front, side and top view to the sheet. For every sheet we have to add the views and position them and preferable align them so that all sheets match.
If, for example, you would have a sheet template with four placeholders, then selecting four views would automatically place them on the placeholders. Then selecting the sheet would allow to fine tune the sheet layout were necessary.
3 Comentarios
No aplicable
This!
Also, please make it possible to duplicate sheets (even if it has to duplicate each view that it uses), so we are sure all sheets in a project are "standard".
craigh_bim
PPI has a plugin that helps with this. Look into their PPI briefcase.
No aplicable
Great, this proves it will be easy to implement it directly in Revit.
Enviar idea
