It would be really helpful to have the ability to share project parameters, detail views / sheets, legends, general notes, etc from one location to multiple projects (live). In an AutoCAD workflow, we can do this using xrefs to have one title block, one set of details, one set of general notes / legends, etc, attached to multiple plans, but in Revit, each RVT file currently needs to maintain it's own version of this information. This is difficult to maintain across several RVT files in the same job.
Also, the term 'global parameter' would make more sense if you were able to pull the data from an external file of some sort, into multiple Revit projects.
