La sugerencia automática le ayuda a obtener, de forma rápida, resultados precisos de su búsqueda al sugerirle posibles coincidencias mientras escribe.
Mostrando los resultados de
Mostrar solo
Buscar en lugar de
Quiere decir:
Esta página se tradujo para tu conveniencia mediante un servicio de traducción automática. No es una traducción oficial, y puede contener errores o traducciones imprecisas. Autodesk no garantiza, ni expresa ni implícitamente, la precisión, la confiabilidad ni la exhaustividad de la información traducida por el servicio de traducción automática y no será responsable por los daños o las pérdidas que se produzcan como consecuencia de la confianza depositada en dicho servicio.Traducir
Shared Parameters in Elevation and Section Marks, Callout Heads and View Referen
On behalf of my 17+ users and numerous times suggested and requested by many other users - please allow Shared Parameters in Elevation and Section Marks, Callout Heads and View Reference tags:
Here is sample list of topics where people have already requested or inquired about this functionality:
Just an FYI for those waiting for this, there is a crazy silly workaround. You can (at least for callout heads) change the family category under [Modify>Properties>Family Category and Parameters] to something like view title, add the shared parameter, add a label with that shared parameter, copy the label with ctrl c, change the family category back to "Callout Heads", paste the label, and now it works...
Note if you do not copy paste the label, the "parameter name" will be reverted to Detail Number when you change the category back.
Hi There, I`m trying the callout head with your suggested method but it didn`t work for me. Can you explain further or shared your revit "call out" family? Thanks
The composite number of votes for this concept, from all the separate "ideas" in the 1st post seems like it would give this some priority. I know that votes, alone, do not determine whether or not ADSK accepts an idea. But, it influences it, and this one clearly has community support.
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
To follow the progress of features in development, please see the Revit Public Roadmap and join the Revit Preview Release to participate in feature testing. (Note that Accepted Ideas may not be immediately available.)
