cancelar
Mostrando los resultados de
Quiere decir:
Shaft Opening can cut Slab edges
If you have a shaft opening that is creating a void in a floor and this same floor has slab edges, when you have placed a shaft opening and depending its top and bottom constraints, (for purpose assume it goes past the slab edge) it would cut this .
I currently have a situation where it is cutting through the floor but not the slab edge
1 Comentario
Enviar idea
