Setting behaviour of Project Browser and Property Palette
Please make it possible to change the settings to Auto-hide for the Project Browser and Property Palette.
See also AutoCAD Toolbar settings (enclosed).
To work faster and have a more efficient User Interface.
1 Comment
sander.van.pelt
Hi Pascal_deleeuw,
This is possible if you go to the %appdata%\Autodesk\Revit\Autodesk Revit 20xx\ folder and edit the RevitUILayout.xml file there.
If you change the values ​​behind "CanAutoHide" from "False" to "True," a pin will appear at the top of your palette.
This allows you to automatically hide your palette.
