Let's imagine you tab along happily searching for the right element to select. Fist you skip by that group you don't need, then you skip that group which extents makes it impossible to see at current zoom level. couple of other tab to skip other adjacent objects and here you go - this is the floor/wall/whatever you wished to select and edit... Inactive. Belongs to group.Yes, that is nice, but WHICH group? Yes, you can make the object editable, but at risk of excluding it from its native group and making a mess of your model.
It would be nice to have a tool similar in mechanics to Select Host for tags, one that would at least point you to direction of WHICH group should be edited to access specified object. Ideally it would open hosting group and keep the object selected. The keyboard shortcut OH would fit perfectly.
