We are currently migrating data within this board to improve the community. During this process, posting, replying, editing and other features are temporarily disabled. We sincerely apologize for any inconvenience caused and appreciate your understanding. Thank you for your patience and support.
Select All Types/Category
Just like there is a Select All Instances function, I believe there should be a Select Category function.  If you right-click a door, you could select the Select Category option (Visible in View or In Entire Project) that would select every door regardless of Type.  This function already sort of exists in the Temporary Hide/Isolate tool, so I don't believe it would be a stretch to make it work simply as a selection tool.
1 Comment
Just like there is a Select All Instances function, I believe there should be a Select Category function.  So if you right click a door, you could select the Select Category option (Visible in View or In Entire Project) that would select every door regardless of Type.  This function already sort of exists in the Temporary Hide/Isolate tool, so I don't believe it would be a stretch to make it work as simply a selection tool.
Tags (6)
