Every time you require a new type of section head you need to create a new type of section tag. This can get quite complicated when you start factoring things like detailed sections, disciplines, colour & b&w versions.... where you might want to create filters to control the visibility of these sections in a view. As per my example I might have 10 different section heads which are all used across board on 10 different disciplines. This means I would now need to create 100 different section tags, and this is only for general section, I would then need create an additional 100 for detailed sections... Would it not make more sense that when a new section head is loaded that you could cycle through all 10 variations of loaded section heads or have an actual pull down on the section head in the drawing area to select the section head type, thereby eliminating the need for creating a number of section tags.
