Section cut line visibility toggle
It would be good to have a setting to control the visibility of the section cut line. ie. turn off or on. We can control the cut lines lineweight and colour but not is visibility. Yes we can create the line as white and dot but that still shows over shaded elements.
This visibility toggle would allow you to avoid always breaking the line and adjusting the section cut line grips.
Unless someone has a way?
1 Comment
Mickael_Andre
it would be great to have the ability to hide sections lines by default and tick a case when the line is needed.
It is very fastidious to clic on the zigzag symbol and drag and drop the lines when there is a lot of sections.
Tags (3)
