This could be any metadata property that is:
Example 1: If I had a number of GM's and the type name was based on a size LxWxB... , but in the description it is known as a Type-X by searching for type-x it would find this.
Example 2: no family name contains 50mm Thk, but by searching 50 it would reveal any family that has a dimension property of 50mm, or even if this is mentioned in description/fire rating...., unless I type 50mm then it would only search for dimension of 50mm
