Schedules - list values vs blank cells
currently when you try to schedule elements that have different values for a particular parameter, Revit changes the cell to appear blank.  Revit should allow the schedule to list the different values.  Could be by default or as a check box option per field.
22 Comments
pieter4
I agree with this idea, but there's already a duplicate idea for this: https://forums.autodesk.com/t5/revit-ideas/schedules-list-values-vs-blank-cells/idi-p/6773032
ClaytonOC
"Multiple Values Indication for Schedules." Please Create an Option that would allow for a listing of all the Output values, in a particular parameter field. For instance if you had a Revision Schedule and you wanted to list all the Sheets for a Revision that has the same revision Mark. The parameter field output would list all the sheets in the field,
 A-101, A-102, A-201, A-301. Etc.  Instead of <varies>. This would be useful for many other schedules, and tags.
Tags (5)
