cancelar
Mostrando los resultados de
Quiere decir:
Schedule - Enable Top Down / Bottom Up in Appearence Tab
Currently it seems that the parameter "Build Schedule" of the "Appearance" tab of the "Schedule Properties" dialog is only enabled for "Revision Schedule". But for any other schedule it is not possible to select if we would like to build the schedule "top-down" or "bottom-up". So all schedule, but the Revision Schedule, are build top-down.
Depending on how schedule are placed on sheets, users needs sometime to build schedule bottom-up. If not depending of the number of row on the schedule they have to always adjust the position of the schedule on the sheet.
So the reaquest here would be to be able to build schedule, including View and Sheet list either top-down or bottom-up.
1 Comentario
Mike.FORM
Under Sorting/Grouping tab you can change this by selecting "ascending" or "descending". Or are you saying you want the headers and title at the bottom too?
Enviar idea
