Save last shared parameter path per project
Currently Revit shows the last used shared parameter file on any project.  I would like to see the last used shared parameter file path saved on a per project basis to avoid confusion and mistakes.
For example might be working on three projects:  A highly custom project with lots of non-standard shared parameters, a project on a typical office template, and a test project where I'm experimenting.
The last used path dominates, so if I've been editing the test project with it's own shared parameter file and go to work on the regular project I'd see only the test values.  Likewise, if I'm working in the custom project I might accidentally save a new shared parameter into the office shared parameter list.  If I jump into a project using the default template I have no indication if that project has a project specific file for extra shared parameters.
It would be helpful if each shared parameter also saved it's origin path to help in locating the correct shared parameter path to add that parameter into other file.
1 Comment
sasha.crotty
Status changed to: Archived
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
Forma Design Contest
Technology Administrators
