With round duct, we tend to use rolling offsets on a project to minimize fittings and cost. The problem with routing solutions is that it will give you some crazy, non-realistic angles (example=60.46 degrees). Is there a way to add a specific angle (example=45 degrees) to use as a parameter in order to skip the lengthy process of rolling an offset manually? I have tried to use the MEP settings under the angle category and it does not work. I would like to see a button or a function that will auto route from one end of the duct to another, no matter where they are located with the ability to select a specific angle or not.
*See attached video with the process we use to roll a duct offset with a specific angle.
