This is a re-post of Rotatable Section Heads since that idea was marked as "implemented" even though the current implementation doesn't give enough control over the rotation, but merely makes "Rotate text with component" parameter have an effect. And also partly because the toolbar (to insert images) isn't visible in replies. 🙂
For us, leaving the (now working) parameter unchecked (the pre-2021 behavior) results in the 4 orthogonal conditions being exactly how we'd like to see them [circled green below], with the rotated cuts being different than our standard (but acceptable - i.e. readable). However, checking it (with the R2021+ behavior) results in only ONE of the orthogonal conditions matching, one being acceptable, and TWO being completely WRONG [circled red below] (the sheet number shows ABOVE the detail number). For the rotated cuts, we gain an exact match, but again TWO conditions are WRONG.
It wouldn't be an acceptable solution to use different types for the different conditions because each section cut appears in multiple views (plans AND sections), so we would need view/instance-based control to show it properly. That would help with the Reference Label problem, but would require a lot of manual fiddling (not sure how well that would fly with our users). Maybe separate symbols for plans and sections would help?
There are similar issues with the static text outside of the bubble, but since there isn't an above/below issue, we'd probably be alright with it ends up - i.e. showing on the left vs the right, or above vs below (though having it get too close to the line isn't good).
For a fully-automatic solution, we'd probably need some kind of "angle on sheet" parameter (so we could have 2 or 4 sets of labels/lines and control their visibility based on the parameter). Or some property for each element that made it "readable" vs "fully rotatable" - i.e. some way to designate what elements are part of the "arrow" (and should rotate the full 360°) and what should only rotate up to 90° counter-clockwise (in each quadrant).
I know there are many who were happy to see this feature, but for those who have more than one Label in their Section Heads, I can't see how this has helped.
