cancelar
Mostrando los resultados de
Quiere decir:
Room seperation line level
knowing the associated level of  room separation line will be so good
5 Comentarios
sasha.crotty
@A_MAQ, could you please elaborate on how you would use this info? I'm trying to get a better grasp of your desired  workflow. It helps make sure we have a shared understanding of the problem.
A_MAQ
@sasha.crotty
the case I faced it with my workflow is I am requested to delete every unused room separators from a file I am working with , so I need to know the associated level to be sure this room separator is for a specific room in specific level
sasha.crotty
@A_MAQ, how would you live to get this info? Are you just selecting a line and need to see a parameter, do you need to filter, schedule, etc? Thanks.
A_MAQ
yes as you suggest, selecting the line and need to see a parameter telling me the level
and the most important thing if it can be done is it the line is roam bounding or not
thanks
No aplicable
Considering the level of the room separation line affects room bounding, it seems a terrible workaround to have to move this in 3D view. These should act more like model lines and/or at least have the level and level offset shown under properties.
Enviar idea
