Allow the base of Rooms to be dragged up not just down. On complex multi level projects where adding a Revit level for each constructed level is just not appropriate, there is a need to bound rooms by room separation lines, which this causes warnings... or bindings room incorrectly... i.e. a step in floor of 300mm should not warrant a new Revit Level, but can cause all sorts of issues. Would end up with 1000's of levels which then results in messy drawings and users modeling/snapping to incorrect heights.
