Room bounding stairs
It would be nice to have a room separator or room bounding for stairs. because now the volume and area are not correct diffend.
See the pict for a solution. It would be better to have a roombounding parameter at every stair.
9 Comments
While we wait for a solution, how is everyone going around this problem? Have tried ceilings for the storage area, but failed for the space above the staircase.
augidomeo
christoph.grossmann
It would be very nice if stairs would limit the rooms. There are so much trouble with incorrect volumina. For now you have to create a floor under the stairs.
Tags (3)
koert.vynckier
Being able to make a stairway Room Bounding should have been possible a long time ago.
S.K.A.I.
zusätzlich sollte die Raumberechnung unabhängig der Berechnungsebene erfolgen, um z. B. auch die Schachteltreppenthematik zu ermöglichen ...
Wir arbeiten hier momentan mit Dächern als Raumbegrenzung 😞
S.K.A.I.
namratakale
Community Visitor
+1 It would be nice to have room bounding option available for every stair instance., since it will be much easier to calculate exact volumes of stair well.
Sleepingfish_Kuo
need this too, the room beneath stairs is often utilized for other purposes.
Kristian_Vyer
Having the ability to attach top/base of walls (and perhaps columns) to stairs would also be very useful!
