Would like to see Revit come up with Roof Options. Under the Roof function you can have an Auto Generate selection. Under Auto Generate you can input the level, pitch, overhang, exterior perimeter or select walls. After that Revit will generate multiple options including dormers as the program sees it. From there you can select as many generated options as you want to present to the client or to your design staff. After selecting you can edit as needed. Similar to Generative Design. Creating a roof now is tedious. I was thinking about this when trying to create a roof for a multi-family residential facility.
Kory Skoog
BIM Manager
