Roof: Fascia Depth
Roof: Fascia Depth
Please add a parameter (to all roof system families) that controls the horizontal dimension of the Rafter Cut. When using the "Two Cut - Plumb" rafter cut option, there is currently only one editable parameter "Fascia Depth".
It would be extremely helpful if we also could control the horizontal cut dimension. It is more common in light frame construction to set the rafter cut based on the framing thickness of the wall (for example 5 1/2" for a 2x6 wall). The plumb cut is less important (a function of roof thickness).
Thank you,
Aaron
