Revit to make isometric of pipe
Isometric similar than Plant3D
9 Comments
Fantin_Jean
Dear,
I work with Plant3D.
But my client ask a final project all 3D in REVIT.
When I export my Plant 3D from EXPORTAUTOCAD I loose all attributes, datas, lines numbers, valves numbers & others.
This is not a good job for him.
I've serched on the web a solution.
In autodesk Products nothing really good.
I'm disapointed. I risk loose my client.
I find this Es-Iso & Ez-Spool from Huensystem.
https://www.huensystem.com/
You know this addons ? Have you tested?
The cost of its addons is important and I cannot afford to test them.
Waiting your response...
In advance thanks
Best regards
Jean
Tags (4)
dbutts7
Have you tried using the IFC export tools to move your model from Plant 3D to Revit? You'll still some features but get most of the 3D model.
thanks - David B.
FelipeMaSilva
One of the most important thing in MEP execution is Isometric drawings. It is not possible to prepare iso darfts in Revit directly. In many piping software, users are able to create Iso Draft without any plugins or auxiliary programs. It is a good idea to have Iso Draft module in Revit.
rbarbosa8DQGJ
Plant3d and Revit does not interoperate in a good level. There is no way to export to IFC file between those two softwares, so I created this idea:
https://forums.autodesk.com/t5/autocad-plant-3d-p-id-ideas/plant-3d-and-revit-integration-via-ifc-fi...
Vote for it.
There is a way to use PCF file format to export/import from and to Revit. Is not that easy but maybe will help you.
https://blogs.autodesk.com/revit/2017/07/26/exporting-pcf-files-from-revit/#comments-section
https://blogs.autodesk.com/revit/2017/07/27/exporting-pcf-files-from-revit-2018-part-2-assemblies/
I also posted an Idea to make this PCF export/import more easy.
https://forums.autodesk.com/t5/revit-ideas/make-isometric-piping-more-easy-with-pcf-file-export/idi-...
Vote for it.
rbarbosa8DQGJ
Vote for it.
Vote for it.
rbarbosa8DQGJ
Vote for it.
Please, Vote for it.
FelipeMaSilva
Já votei meu amigo. @rbarbosa8DQGJ
precisamos nos unir para melhor os software aqui para o Brasil.
rbarbosa8DQGJ
Show!
mwiggins
when are we going to get a Plant3D addin for Revit?
