Revit terrain - Link topography via BIM360 - Phases
Advantage of Link topography via BIM360:
- the terrain is imported without loss of information
Disadvantage:
- the imported terrain cannot be assigned to a phase
Suggestion for improvement:
- Phase must be assignable
Added on behalf of user.
2 Comments
dominik.malec
Advantage of linking topography via BIM360:
Disadvantage:
- the imported terrain cannot be edited in Revit (lack of material assignment)
- Make material assignable
Tags (5)
pieter1
I always found it weird that topo reacts differently to phases than other elements. For example: when we modify a wall, we don't build two walls (old and new). We just add 'actions' to the wall (a new opening to an existing wall). Topo should work the same way.
See this idea: https://forums.autodesk.com/t5/revit-ideas/fix-topography-not-responding-to-phases-properly/idi-p/68...
