Revit Rooms
Revit Rooms
Maybe a way to remove Rooms not placed in a project a little faster. I feel the current way takes too long, in the later stages of a project when it is borderline out the door it can be a bit of a hassle.
2 Comments
eprunty2
Create a room schedule with a filter to include rooms with area less than 0. Untick itemize every instance on the schedule so when you select the row you select all redundant, not enclosed or unplaced rooms for bulk deletion.
Grouped rooms need to be deleted per group in the group editor or else they'll just be excluded from each group instance, but this works for all non-grouped rooms.
eblackburnEFFVJ
pyChilizer (part of pyRevit plugin) has a Purge+ > Remove Unplaced Rooms tool that makes this very fast and easy. Also Areas and other items like DWGs, Scope Boxes, unused Sheets, etc. It's an extension that needs to be enabled after you install pyRevit.
