Revit room on multilevel
here's an idea:
Revit does not automatically recognize rooms on more than one level if the rooms are not aligned. In the attached example, the room makes a 90 degree between 2 levels (it is for a staircase in this example)
I have tried to Enable volume calculations, but it only works partially.
here is also the post with the community tests: https://forums.autodesk.com/t5/revit-architecture-forum/room-on-2-level/m-p/11217294/highlight/false...
Apparently it works with Space analytics, but not with rooms.
This would be a nice feature to have and also useful for a multi-level room.
here the image and file for the community to test : https://www.dropbox.com/s/oyaj68thujzsayx/defi%20escalier.rvt?dl=0
