Revit Recovery after Revit crashes / Local cache autosaved setting
it would have a way to get a "Revit File Recovery" for projects saved on bim 360 document management
Or/and
To implement an option to Autosaved on the local cache those bim 360 projects and in case the file crashes, at the re opening of Revit , Revit should displays "the recovery of your file xxxxxxx.rvt is located under this path : C:\Users\xxxxxxx\AppData\Local..." by indicating the path where the local cache is saved it would help user because the path and the folder names are a kind of weird.
Then the "Autosaved" function would come with a set up....similar at Autocad, to trigger the action of the Autosaved after a command is completed (not during processing command).
Thank you
4 Comments
It will be really helpful
And the recovery file has no link anymore to the online model. This can also be addressed as a problem. Re-initializing a new cloud model may not be an option anymore, due to continues work by others.
+1
J___M___
jmartucci2
anybody home autodesk???????
