cancelar
Mostrando los resultados de
Quiere decir:
Revit open more than one file in the same tine
we hope revit has the ability to open more than one file in the same tine.
5 Comentarios
Revit already supports that.
elzohry2007
@ameer.mansourWAK8Y
revit does not support opening more than one in the same order
file
open
you can not select more than one file
revit support opening more than one file in the same session not in the same order
try to select more than one file
and that will help you with what?
dplumb_BWBR
When I need to open multiple Families, I select them in Windows Explorer, right-click and Open.
However, I would NEVER use this for opening Projects. Too easy to open a Central file using that technique.
michael-coffey
You can also drag-and-drop multiple families from explorer into an already running instance of Revit.  So that you can be sure that they will open in the correct version
Enviar idea
