Revit Icons Support High-Resolution Display
I know Autocad support high-resolution displays images for the button icons. Revit could have the same thing and show a high-resolution icons when the user have a high-resolution displays.
I copy some similar Icons from Autocad and put inside Revit just to compare with the default icons from Revit.
In the image: The screen scale is 200%, on the left the standard Revit icons appear bluer and on the right the Autocad icons looks sharp.
Here some reference how that could be done with plugins inside Revit.
5 Comments
 Title says all, I suggest 4k Display support for imminent future of higher resolutions.
pieter7
This has been implemented in 2017.1
julien.ready
Revit should be able to have a "4k" option to have all icons + menus scaled to fit the monitor 3840x2160 (4k) resolution.
Actually, the only ways to have decent icons and menus size on a 4k monitor are:
  • to have Windows scale options activated, which is not recommended to use with Revit.... and reduces the resolution as well.
  • if you have multiple monitors AND Revit 2019, have your revit main window on a lower resolution monitor (for example 1680x1050 on a 22'' monitor) and a drag windows on the 4k monitor (since it's now available with r2019). But you won't work with same resolution monitors.
intereric
When making use of more monitors with different resolutions and scalings, text and icon become blurry when moving from e.g. a 4k monitor (150% scaling)  to a HD monitor (100% scaling).
Programs that are working fine with scaling are programmed as "per monitor scaling".
Autodesk products are "system scaling". It only works fine when logoff/logon.  Until you change the program to another monitor, you can start over again.
Please fix this Autodesk.
Tags (1)
dbobber
Autodesk, we no longer use small monitors with small resolutions. Often have to back out of views to see the adjuster crop region dot. Has anyone else wished they added more adjustment dots? Especially on a 4k monitors this would be great.
Tags (1)
