Currently with fabrication pipe in Revit you are unable to set the Spot/Invert Elevation tagged parameters to go off of a different value than level. For example, when doing underground pipe it often needs to be based off of sea level (project base point), not offset from level. I.E: we want to see 347' - 6" not -2' - 1".
You are unable to change what the spot elevation parameters are referring to with fabrication pipe like you can on a typical spot elevation tag. If a spot elevation tag is used instead of the native fabrication part-tagable spot elevation parameters it has unusable values.
