So when using Fabrication in Revit, if you have 2 pipes and you wish to connect them, you can drag the grip of Pipe 1 and connect it to Pipe 2. This results in a connector ITM.
First, it would be nice if it didn't add the connector. (Just like when modeling using Revit piping). 99.9 percent of the time, I connect the pipes and then delete the connector. If anything, it would be nice if there was an optional checkbox that determined if a connector was added during routing.
Second. If the pipes are not straight with each other, such as a 90 degree corner, then they won't connect. Granted, you can use Route and Fill, but that still adds the connectors as described above. It would be awesome if you could grab one pipe, drag it to the other, and have it add the necessary elbow (following the rules of the Multi-Point Routing feature)... and not have any additional connectors.
