Show only
Search instead for
Need your attention here. Is there some information about possible changes in API for this? Usage of mass in families or directshapes makes editing on the fly so hard.
Not as far as I am aware. Collecting votes. You can keep an eye on the immediate future developments in the Revit API by subscribing to the preview release in the Autodesk feedback forum https://feedback.autodesk.com/overview/default.html
Would be extremely helpful to be able to construct editable in-place masses (constructed with reference and/or model lines) through the API or Dynamo. A perfect example would be loading in a 2D CAD survey or registry plan and use the curves to create in place massing massing geometry on the fly. Would save heaps of time, whereby we would otherwise need to create a new family, manually trace the outlines, extrude, add material parameters, etc. Over dozens or even hundreds of buildings per project this would be a huge time saver.
