Revit 2022 Links Nomenclature
Currently, links in Revit 2022 are tough to differentiate from a Published model vs a Collaborative model.  In previous versions Published models are pathed through "Autodesk Docs" and Collaborative models are pathed through "BIM360".  Revit 2022 pathing always starts with "Autodesk Docs" and the only way to differentiate the type of model is to watch out for the Project Hub in the "saved path".  If the "saved path" contains the Project Hub, it's a Published model.  We need a better way to distinguish between the two.  This can cause confusion and potentially lost hours and re collaborating if the wrong model is linked to a Revit 2022 project.
Rail Community
