Revit 2020 : Universal Open Database & Integrated VB Programming capabilities
If we are going for pie-in-the-sky- revit could use a major overhaul (Revit user since 2006)
This is in 5 parts:
  1. Family categories open for editing/purging -base system components remain with GUIDs intact
    • Family-dependent subcategories with their own GUID- Creating "door.frame" makes the "frame" compatible with all "door" family types, scheduled by its own subtype, or as a subtype of door (e.g. door schedule parameter door.frame[all subcategories of door available here to door.frame]
  1. Linetypes editable//accessible by GUID in the linetype editor:
    • Show/ Use [None |<System> | NickName |  Generative]
      1. None= not allowed/shown for use in this project
      2. <System>=use default system name (greyed out for non-system items)
      3. NickName to show user-defined names for sets
      4. Generative = use generative system to generate names and sets (Given formula and data generate line type and name them by a formula)
    • Substitute Linteype (For each non-conforming linetype)
      1. Map unused linetypes to the next adjacent
      2. Map imported mismatched linetypes to those allowed
      3. [conform] to permanently re-map the linetype
      4. [Save] list mappings [GUIDs -> Remapped]
  1. All components are shared and reliant upon #1 to identify family sub-content. Sub-content can be brought into a family along with generic annotations.
  2. Open database allows for any component and host components in families to be referenced using intellisense. E.g. in a door family, the "host<WALL>.structure.core.width" is accessible as a variable, as would be " host<WALL>.structure.core[1].material.identity.type
  3. Database integrated and accessible on a LIVE bases - e.g. Built into SQL
    • where database can be queried,
    • or manipulated by an outside source.
    • Common database lookup could provide 'open source' subfamilies with common GUIDs provided VIA blessed content by Autodesk for use by all (Translated options available for "Nicknames" - GUIDS remain the same for same content- us Machine learning to map across languages and concepts).
VB style formulas with VB functions (Including concatenate, string manipulation and REGEX!)
All menu and components can be modified/remapped - e.g.
  • coarse/med/fine can be remapped and supplemented: LOD100<Coarse>, LOD200<med>, LOD300, LOD400<fine>, LOD500
  • Profiles and other components can tie into this system using the <SYSTEM> names or NickNames (Nick names appears on the list)
And soforth- a complete overhaul.
2 Comments
WM_Ron_Allen
This is in 5 parts:
Tags (2)
Alice.Santman
This is great list for 2020 updates.  But I'm wondering what is the most 'complained' about yet simple Revit feature over the past, let's say, 5 years (Possibly longer even)..... which needs to be fixed?  Come on - you all know what I'm speaking of.....
RAILINGS!!  This one is very simple Autodesk - just go get a few seats of ArchiCad and copy how they do theirs.  NOT KIDDING!  I have used both platforms (Archicad since 1996, Revit 2003) and Archicad completely rocks on railings and stairs over all others.  If you have never used Archicad, take the time to test it and do a compare - you're eyes will be opened as to what's possible.  Oh, and yes backwards compatibility is possible.
Happy New Year!!
