Revisions Solution for IPD Projects
Revit Revisions - For the Trade Contractor in an IPD type project.
Currently the only work around for creating revisions that I know of, for working in an IPD project where the contractor is modeling within the design engineer's model is to place a generic annotation family for the revision delta and manually draw arcs for the revision cloud, and manually add text to the revision block which is pretty lame and hard to manage, as well as time consuming and no visibility control afforded like the traditional revision functions. Typically architectural and engineering design firms want the revision status to be set to a "per project" basis, when the contractor needs to add revision for field changes, this would only allow a consecutive numbering system throwing off the revisions shown on the engineer's sheets. This has been an on going problem and it's time for a solution in this collaborative environment.
1 Comment
taskelson
An option to be able to select either option on a per sheet basis with two different numbering sequences would work..
