Reporting X/Y/Z point for families
A reporting point in families that would report (read out to tags) its postion in relationship to the project base point and/or the survey point would be very useful. The point should be nameable and attachable to reference lines, reference planes as well as to object geometry in the family. The reported values should go into tags and schedules.
An application would be to read out all door sill heights in absolute height coordinates without passing by a dynamo script (perpetual source of errors due to forgotten script runs). There are certainly hundreds of other useful applications for such a point.
Libre cours à votre imagination - unlock your imagination.
14 Comments
splint3r
Great idéa @steiner! I would also benefit from such a feature in my work.
blro.
We need the ability to gather a family's dependents Level height(s) (both Absolute - from the Surveyor Point and Project Base Point), as well as the families' offset from these Levels - so that we can calculate absolute points within individual components - then schedule and tag this data. This needs to be live information - opening Dynamo and running a script every time a window height changes is unjustifiable.
Spot elevations achieve this only partially with their bottom and top heights - this approach would allow much greater flexibility. In addition, when families are edited and reloaded, often these spot elevations get deleted as it loses its host geometry (I assume) - another problem for another post.
I imagine this looking similar to how Room Information can usually be scheduled within another category, except,
of course, that this would also be available within the Tag Families' environments.
The new 2020 feature of some MEP items getting their elevation heights in schedules (as well as sill heights for windows always being there) was a good first step.
Now let's get this all the way there.
Rivera-Artes
is incredible that software with more than 10 years can't offer the X,Y,Z parameters of the object in the properties of in the schedule.
Please make the parameter available.
ipselute
I hope you're talking about length, width and height / depth parameters. Because X,Y,Z are just cartesian coordinates. And those parameters have constant values only for the simplest shapes (3D primitives). For complex shapes , like conceptual masses, all parameters are variables defined by some functions. Displays functions might be useful too.
Revit has too little engineering (maths) aproach.
We also need Level dimensions in schedules. To easily see Base level and Top level of walls, beams, columns, etc.
Hi Rivera-Artes
I understand your wish, had the same problem. We are used to coordinates like in AutoCAD or others applications and working in projects, which where georeferenced.
As far I understand the logic of Revit, you must look at your model itself viewed locally. You can define a georeference point, but the software doesn't work with the georefenced system. If you want coordinate lists for the execution of your construction, I recomend you to create a point family and write a Dynamo Skript to it. From there you can create the X, Y, Z parameters and file them in the model, and further export the data to excel.
The Skript is a easy math, vector geometry: transforming the vectors on the local reference to the georefenrence ( rotate + move)
wr.marshall
Firstly some related ideas
Scheduling Spot Coordinates and spot elevations
Structure Foundation_pile coordinates in schedule and Quantity
Schedule to report coordinates of structural framing (Archived)
Acquiring coordinates from Columns
Export XYZ coordinates using shared parameters
In addition for the odd cases where columns are not sitting on a rectangular grid there needs to be a way to schedule the angle of a given element.
zhaohui.chen5TEA7
Revit definitely has all the coordinate information in a model. Use sport coordinate can get the information one at time.
I don't understand why Revit doesn't provide xyz parameters which can be easily controlled by user for scheduling etc.
xyz parameters should be a basic functionality.
How to show piles coordinate in pile schedule?
steiner
There is an idea with a similiar Goal https://forums.autodesk.com/t5/revit-ideas/reporting-x-y-z-point-for-families/idi-p/8710430 . Please consider voting. @Anonymous: https://forums.autodesk.com/t5/user/viewprofilepage/user-id/10017618 Please consider the need of building parts "knowing their heights" in german speaking building enviroment. We had a contact back in 2009 with Autodesk about "heights" in building parts. At that time we were dealing with heights of windows. Autodesk answered us to use "Revit Architecture 2009 Österreichanpassung" (the little red point to set spot elevations), which didn't work for the reason told by @blro. "often these spot elevations get deleted as it loses its host geometry". Also please consider merging votes for similiar goals.
bjoern_teutriene
There is an app for this purpose called BiMTOOLS and it's for free. They use a generic model family called "Einfügepunkt.rfa" which you can place directly in the project or nested in families, e.g. in an individual foundation. Furthermore, you receive heights of doors, windows and wall openings always updated.
wr.marshall
The ability to create a coordinate point in the family editor which can be locked to  an object like a reference plane so if there is an adjustment in the dimension it would update it's position.
When the family is then loaded into a project you are able to get the coordinate of this point and able to schedule.
The Coordinate point should also be able to be named
As an example: on a rectangular column I could place a coordinate point on each corner. If I place the coordinate point top left in the family editor and called this "C1" when I load this into the project and turn the column 180 degrees "C1" would now be bottom right.
Tags (3)
steiner
23.01.2026 Still no point at the horizon after 6 years. Fortunatly imagination is still alive. To give birth to this "point" vote before we have reporte his disappearence.
18.02.20260 still cant find.
steiner
Continue to motivate your coworkers to vote. If we multliply the 80 votes by 10 there would be a chance to get the point. Lets see whats possible with pyRevit. Maybe someone has a little bit of time to spend and the neccesary skills? On YT there is a video on that topic.
