Related to the A360 request here: https://forums.autodesk.com/t5/a360-ideas/a360-sheets-sort-order/idc-p/6503861#M1914, this is the Revit side of the issue.
When selecting the views for A360 there needs to be a way to specify what order they appear in in the A360 viewer. Often sheets are not in alphanumeric order. For example we always have G sheets that come before any A sheet. This could be done several ways:
By parameters (preferred, since it doesn't require the system to be recreated or constantly managed in multiple places)
Allow the browser organization style for sheets to be used, or a similar ordering style developed where the sheets can be sorted by a specific series of parameters. Viewing them in the same order would also make it easier to be sure all needed sheets are included.
Resorted using up/down arrows (more time consuming, and has more opportunities for errors if a sheet is added and not sorted)
Like parameters in the family editor, sheets could be selected and rearranged to reach a desired order.
Once this is developed it could also be used for the print command!
