cancelar
Mostrando los resultados de
Quiere decir:
'Remove View from Sheet' instead of 'Delete' in right-click menu
When i want to 'Remove View from Sheet' i select the view, right-click, then press Delete. But i don't want to Delete View from Project, i just want to remove it from sheet, hence my confusion. 'Delete' could by replaced with 'Delete from project' for more precise intention.
1 Comentario
Hi, @victor_vijeuKD42L ,
Just for clarification, when you click on a viewport, right-click and select "Delete", the view is not deleted from the project. It is removed from the sheet. I like your suggestion to rename the function, though.
Also note that "Remove from Sheet" is available when you right-click on the view listed under Sheets in the Project Browser.
Thank you for your Idea submission!
Enviar idea
